Common problem for novice mercurial users is not getting “fingerprints” for their HTTPS repository servers.
It’s usually recognized by getting next error when trying to push/pull from protected HTTPS repository:
abort: error: _ssl.c:507: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
To fix this issue just get a SHA fingerprint and store it in your configuration file.
Windows systems
For GUI configuration (here example from TortoiseHG).
- Press View>Syncronize.
- Make sure you have https in protocol selection box. Then press yellow lock button
- Now select “Verify with stored host fingerprint (good)” and press Query to retrieve and save server SHA fingerprint.
- Ensure correct username and password in User Authentication fields.
- Save settings.
Alternative way, manual configuration edit mercurial.ini configuration file.
[hostfingerprints]
dev.xdevs.com = 9d:d7:a7:37:47:f1:86:52:a4:05:1b:47:23:ce:1e:3d:6f:60:a4:f0[auth]
dev.xdevs.com.prefix = dev.xdevs.com
dev.xdevs.com.username = your_username_here
dev.xdevs.com.password = your_password_here
Now push and pull operations should be working just fine.
Modified: Sept. 17, 2014, 9:40 p.m.
