Here are a few examples for aliasing snap functions …
funckey f "prepopup;pop dyn_option_select 'Snap pick to@:@Figure'" funckey i "prepopup;pop dyn_option_select 'Snap pick to@:@Intersection'" funckey c "prepopup;pop dyn_option_select 'Snap pick to@:@Arc/Circle Center'" funckey v "prepopup;pop dyn_option_select 'Snap pick to@:@Via'" funckey SF3 "prepopup;pop dyn_option_select 'Snap pick to@:@Shape Center'"
source $TELENV ### User Preferences section ### This section is computer generated. ### Please do not modify to the end of the file. ### Place your hand edits above this section. ### set appmode = signalintegrity set padpath = $padpath F:/Cadence_demo/lib/ set modulepath = $modulepath F:/Cadence_demo/lib/ set psmpath = F:/Cadence_demo/lib/ $psmpath set parampath = F:/Cadence_demo/lib/ set devpath = $devpath F:/Cadence_demo/lib/ set padentry_factor = 10 set allegro_etch_length_on set autosave_time = 10 set autosave set pcb_cursor = infinite set showelement_brief unset showelement_xhatcharea set showelement_highspeed set all_license_choices funckey a add connect funckey i show element funckey r iangle 90 funckey g grid toogle funckey f "pop mirror" funckey Del delete funckey v change_vianet funckey e move unalias F6 funckey t toggle funckey z "pop Add via" funckey q done funckey " " "pop bbdrill -cursor" funckey ~@ FORM vf_vis colorview_list Film: TOP funckey ~1 FORM vf_vis colorview_list Film: INT1 funckey ~2 FORM vf_vis colorview_list Film: INT2 funckey ~3 FORM vf_vis colorview_list Film: INT3 funckey ~4 FORM vf_vis colorview_list Film: INT4 funckey ~5 FORM vf_vis colorview_list Film: INT5 funckey ~6 FORM vf_vis colorview_list Film: INT6 funckey ~7 FORM vf_vis colorview_list Film: INT7 funckey ~8 FORM vf_vis colorview_list Film: INT8 funckey ~9 FORM vf_vis colorview_list Film: INT9 funckey ~0 FORM vf_vis colorview_list Film: INT10 funckey ~= FORM vf_vis colorview_list Film: BOTTOM funckey ~S@ FORM vf_vis colorview_list Film: ASSYTOP funckey ~S1 FORM vf_vis colorview_list Film: ASSYBOT funckey ~S2 FORM vf_vis colorview_list Film: SILKTOP funckey ~S3 FORM vf_vis colorview_list Film: SILKBOT funckey ~S4 FORM vf_vis colorview_list Film: MASKTOP funckey ~S5 FORM vf_vis colorview_list Film: MASKBOT funckey ~S6 FORM vf_vis colorview_list Film: PASTETOP funckey ~S7 FORM vf_vis colorview_list Film: PASTEBOT funckey ~S8 FORM vf_vis colorview_list Film: INT8 funckey ~S9 FORM vf_vis colorview_list Film: INT9 funckey ~S0 FORM vf_vis colorview_list Film: INT10 funckey ~S= FORM vf_vis colorview_list Film: BOTTOM funckey c assign_net
put into skill dir
Loading skills into editor example:
skill load("skill/change_net_on_vias.il")
or
skill load("skill/net_assign.il")
Issue: Cadence Allegro 16.6 unable to generate NC Drill file, just hangs on progress bar while output NC drill. BRD-file located on Windows subst logic drive.
Solution: Copy file to physical drive, instead of subst directory, then NC drill will be working fine.
Modified: Dec. 28, 2016, 7:07 a.m.
