Custom colors setup
Some electronics engineers prefer to use non-standard colors for their IDE’s.
Staring on bright screen whole day, from morning to evening definitely not healthy,
so here’s quick tutorial how to setup black background colors in Cadence OrCAD Capture schematics editor.
Manual setup
You can proceed with manual adjustment for all colors via Options/Preferences.
Using previously saved configuration file
Or much faster way is to use already existing configuration.
Capture stores all it’s settings in INI file named Cadence.ini.
Colors are saved in that INI configuration as well. Since it’s a normal formatted text, we can easily see color settings and their RGB values.
[Default Colors] Off-Page Connector Text=RGB(255, 0, 255), TRUE Pin=RGB(255, 0, 0), TRUE Part Body=RGB(117, 166, 115), TRUE NetGroup Block=RGB(255, 128, 0), TRUE DRC Marker=RGB(0, 128, 0), FALSE Part Reference=RGB(255, 255, 0), TRUE Comment Text=RGB(128, 128, 192), TRUE Hierarchical Port=RGB(255, 0, 0), TRUE Part Value=RGB(128, 255, 0), TRUE Pin Number=RGB(187, 187, 0), TRUE DNI Part=RGB(128, 128, 128), TRUE Variant Part=RGB(0, 128, 0), TRUE Grid=RGB(136, 136, 136), FALSE Hierarchical Block Port=RGB(0, 128, 64), TRUE Wire=RGB(135, 160, 159), TRUE Hierarchical Block=RGB(0, 128, 0), TRUE Title Block=RGB(141, 153, 102), TRUE Locked Object=RGB(129, 159, 182), TRUE Power Text=RGB(255, 255, 0), TRUE Display Property=RGB(255, 128, 0), TRUE Part Body Rectangle=RGB(64, 128, 128), TRUE NetGroup Bus=RGB(0, 128, 192), TRUE Connection Square=RGB(128, 128, 128), FALSE Off-Page Connector=RGB(255, 0, 128), TRUE Alias=RGB(255, 0, 0), TRUE Bookmark=RGB(0, 128, 0), FALSE Bus=RGB(0, 0, 255), TRUE Selection=RGB(255, 255, 255), FALSE Background=RGB(20, 20, 20), FALSE Hierarchical Port Text=RGB(0, 255, 0), TRUE No Connect=RGB(128, 64, 0), TRUE Title Text=RGB(128, 0, 255), TRUE Junction=RGB(128, 128, 64), TRUE Comment Graphics=RGB(128, 128, 255), TRUE NetGroup Pin=RGB(128, 0, 64), TRUE Hierarchical Block Name=RGB(128, 64, 0), TRUE Pin Name=RGB(192, 192, 192), TRUE Power=RGB(255, 128, 0), TRUE
INI-file stored in Cadence home directory, which is setup when IDE was installed.
You can check your home directory setting by running Control Panel\System\Advanced system settings\Environment Variables…\User variables\HOME
I used Cadence OrCAD Capture version 16.6.0 so in this case absolute path for INI-file was next:
c:\Cad_data\cdssetup\OrCAD_Capture\16.6.0\Capture.ini
You can download configuration file with colors depicted above by clicking here
Modified: Nov. 3, 2016, 4:03 a.m.
