Bit swap in byte, per this useful article
uint8_t byte_reverse (uint8_t x) {
x = (x >> 4) | (x << 4);
x = ((x & 0xcc) >> 2)|((x & 0x33) << 2);
x = ((x & 0xaa) >> 1)|((x & 0x55) << 1);
return x;
Conditional error messages. Sometimes there is need for debug output with different parts of string text, depending on input condition test.
#define SELF_TEST_FAIL 1 uint8_t selftest = 0; // Self-test value char resstr[15]; // Char string for values strncpy(&resstr[0],"PASS \r\n",7); // This is good result text strncpy(&resstr[8],"FAIL \r\n",7); // This is fail result text // Some code here to update selftest value...
Line below prints either PASS or FAIL message, depends on condition selftest == SELF_TEST_FAIL
printf ("\033[0;35m-i- Test result ....... %.*s", 7, (selftest == SELF_TEST_FAIL) ? &resstr[8] : &resstr[0]);
%.*s used to output only seven characters from the string address.
Setting a bit
Use the bitwise OR operator (|) to set a bit.
number |= 1 << x;
That will set bit x.
Clearing a bit
Use the bitwise AND operator (&) to clear a bit.
number &= ~(1 << x);
That will clear bit x. You must invert the bit string with the bitwise NOT operator (~), then AND it.
Toggling a bit
The XOR operator (^) can be used to toggle a bit.
number ^= 1 << x;
That will toggle bit x.
Checking a bit
To check a bit, shift the number x to the right, then bitwise AND it:
bit = (number >> x) & 1;
That will put the value of bit x into the variable bit.
Changing the nth bit to x
Setting the nth bit to either 1 or 0 can be achieved with the following:
number ^= (-x ^ number) & (1 << n);
Bit n will be set if x is 1, and cleared if x is 0.
Modified: June 7, 2025, 11:54 a.m.
